RE: Missing Cooling and Warpage Analysis in iSLM Auto Launch Workflow
When using Auto Launch, I selected a Workflow that includes Cooling and Warpage analysis, but the final results do not contain these two items. Why is this happening?
The reason for this issue is that although the Workflow includes Cooling and Warpage analysis, the user has used Gate Design Discovery. When the project only has gate without a complete runner system, these two types of analyses cannot be performed. Therefore, if you want to run Cooling or Warpage analysis, it is recommended to manually select the gate option. Additionally, when manually creating the gate, use the Runner & Cooling Channel Wizard to complete the runner and cooling channel setup. This will allow both analyses to be executed successfully.
