How to export node-level simulation results (temperature and pressure) from Moldex3D 2025?
Dear Moldex3D Support Team,
I am currently using Moldex3D 2025 and I would like to export simulation results at the individual node level for further data analysis.
Could you please advise me on how to export the following node-based data from Moldex3D?
- Node ID and node coordinates (X, Y, Z)
- Temperature history at each node during the filling/packing process
- Pressure history at each node during the filling/packing process
- Other available node-based result data
I would like to obtain the data in a format that can be processed externally (such as CSV, TXT, XML, or any API-accessible format).
I have checked the available export functions and the FEA Interface, but I could only find methods for exporting mesh data. I could not find a method to extract result data associated with each node.
Does Moldex3D 2025 provide any API, command, or post-processing tool to access node-level temperature and pressure results? If yes, could you please provide the related documentation or workflow?
Thank you very much for your support.
