RE: Material Wizard 2024 does not support Windows 7 and earlier operating systems
From 2024R1, Material Wizard no longer supports Windows 7 or earlier operating systems. Material Wizard may fail to open (no response upon clicking) when attempting to launch from Moldex3D Studio.
  • If this happens, you can try running Material Wizard directly by double-clicking mdxmatwzd in the installation directory (Moldex3D\2024(or the version you installed)\Bin\matwzd). A warning message will appear, indicating an error related to a missing procedure entry point.
  • If you or your customer encounter this issue, please check the version of operating system and test it in the installation directory first!
Material Wizard 2024 不支援 windows 7 (含)以下的作業系統
Material Wizard 於2024R1(含)開始不支援windows 7(含)以下的作業系統,Studio開啟Material Wizard會遇到開不起來的狀況(點擊後沒反應)。
  • 此時若在安裝目錄下(Moldex3D\版本\Bin\matwzd)直接點兩下執行Material Wizard(mdxmatwzd),就會跳出警告視窗告知無法找到程序輸入點的錯誤訊息。
  • 因此若有遇到自己或客戶的電腦遇到開不起來的問題,可以先注意作業系統版本和在安裝目錄測試喔!
Kuo-Ping Asked on 20 8 月, 2024 in Moldex3D.
若客戶將Win7更新到更高的版本有困難
是否有其他方式可以讓客戶在2024下去選材料呢
Answered on 10 3 月, 2025.
