How to generate scaled-up deformation results using the Report Wizard?
As far as I knew, the auto report can generate the deformation picture as below command:
#Image_Result_Warpage_TotalDisplacement_Deformation
But this is only creating the deformation result with scale 100%, what if we would like to have 2 times or 10 times result, how could we write the command?
Thanks.
