RE: why the function is disappeared since 2024R1 ?
about FEA Interface,
Q1. why check box for weld line output is disappeared ?
Q.2 why does xml file not to output from 2024R1 ?
Hello,
Here is reply to you.
1. Weld line output is still there. Could you check again or try re-install?
2. The xml file should be the fiber orientation data from Moldflow or Sigmasoft, which is not supported by Moldex3D.
File format of Moldex3D fiber orientation data exported is o2d.
