RE: Warning when clamping force exceeding the machine limit?
Can we set the Moldex3D analysis to give a warning or error when the clamping force exceeds the machine capacity?
Yes, in the upcoming 2025 version, there is a new function for user to set up the clamping force limit.
When the calculated clamping force exceeds the limit, the software will not only provide the warning, but also adjust the calculation within the limit.
