RE: Update Molding Defect Result takes a lot of time
if one changes runs there is often the following popup (Update Molding Defect Results), which takes a lot of time. Does it relate to a specific results and if yes, is it possible to avoid it?
Marcus Asked on 14 5 月, 2025 in Moldex3D.
This window mainly displays a progress bar for actions that take a relatively long time to complete.
“Update Molding Defect Results” primarily involves loading air trap and weld line results. This process usually doesn’t take much time and is only required the first time you switch to that group. Currently, it cannot be skipped.
Answered on 15 5 月, 2025.
