RE: The temperature tolerance settings in Cool solver
Do you have a short overview with the differences between the temperature tolerance settings in Cool solver? Are there some recommendations when to use which option?
This function in cooling solver is used when the temperature is less than user-set tolerance, which means the process is at steady state, temperature calculation will be ended.
Maximum variation of mold temperature
Compare time at initial state of each cycle
Suggest using to confirm mold can reach steady state
Cavity surface average temperature
Suggest using in normal situation
Maximum variation of part surface temperature
Suggest using to capture part minor changes
The three tolerance criteria had been set up for convergence conditions in the beginning of the cooling solver and through series of simulation experience, the default ” Max variation of mold temperature” and the parameters is the most recommended. It have a proper calculation time, acceptable convergence and a reliable result.
