RE: Submit batch run- selceted time
I have a question about submitting batch runs. If I schedule these at specific times, is there a way to check the times I selected/set? For example, if I schedule Run 1 to start at 1 o’clock and Run 2 at 5 o’clock, I am selecting two different times. However, if the batch manager is still open, I can only see the last set time. How can I view the time I set for Run 1? Or does it not work to schedule two runs at different times, and Moldex3D only uses the most recent time for both runs?
This feature currently only supports a single time setting, meaning any subsequent settings will overwrite the previous ones. Multiple settings are not available, and Studio must remain open at all times. Thank you.
