RE: Save customized Run Summary display items
Can the default display items in Run Summary be saved? It’s inconvenient to set them up again for every new run
The display items in Run Summary can be exported as a *.json file. You can then import the *.json file to load the same display settings, allowing you to use them across different computers and projects.
