RE: Moldex3D crashes when using the 1/4 symmetric function
A new bug occurs when I launch the ¼ symmetric setting; the software crashes immediately without any apparent reason. Please help check it.
Marcus Asked on 12 9 月, 2024 in Moldex3D.
This bug has been fixed in the 2024R3 version.
If you are using a version earlier than 2024R3, here is a temporary workaround.:
In short, once the symmetry setting is configured, it can be retained. Here’s what you need to do:
  1. Start with a model that has the symmetry setting already applied
  2. Delete all components inside the model.
  3. Create your model or import your model.
Since the symmetry setting is already configured, generating the mesh will result in a successful symmetric solid mesh.
Answered on 12 9 月, 2024.
