RE: Max Task Core Problem?( Performance cores & Efficient cores)
In the previous version, I could run the analysis using 20 cores. However, in the 2024R1 versions, the computing manager no longer displays all my cores.
Since the 2024 R2 version, the computing manager has only shown performance-cores as the default setting. This is because performance-cores are faster and using other cores might cause some issues.
