RE: Is it possible to consider a vacuum condition in the simulation?
I have a vacuum setting in my design which helps the venting. Is it possible to setup this kind of BC in the simulation?
Yes, a vacuum system could be considered by the venting BC setting.
Users could go for the Venting function in “Boundary Condition” tab.
Both the feature line of the geometry and the edge of the mesh could be chosen as a boundary.
In the setting profile, you could setup an air pressure that is lower than 0.1 MPa (atmospheric pressure) and the solver would consider it as a vacuum BC.
