RE: How to relocate iSLM?
Is there any document that can tell me how to relocate iSLM?
If possible, please simply describe the process.
Evan Asked on 6 2 月, 2025 in FAQ.
The following will introduce the relocation steps for different hosts:
Step1. Stop iSLM service of Server1:
Launch MDXiSLMStartUpTool as Administrator and then Stop all services
Step2. Stop iSLM-DB service of Server1:
Excute Moldex3D iSLM Stop DB as an Administrator, and use the job administrator to confirm that all services starting with Moldex3D iSLM have been Stopped. If there are any, you can right-click to stop it manually (Moldex3D iSLM DataBase Server should be the least stopped)
Step3. Copy the database of Server1 to Server2:
Copy the folder data into the iSLM-DB installation path of Server1 (or another user-specified path during installation) to Server2. It is recommended to place it in the default path C:\Moldex3D\iSLM-DB or a disk with larger space
Step4. Reinstall iSLM and iSLM-DB on Server2:
Launch installation of iSLM (optional) and iSLM-DB on Server2, and directs the iSLMDB Data Folder to the folder copied from Server1
If there are other situations or if you need to move different hard drives with the same host, please contact your agent or sales representative for more detailed information.
Answered on 14 2 月, 2025.
