RE: Error 4000 during cooling in an overmolding simulation
I am facing an error 4000 during cooling in an overmolding simulation, and I am not able to solve it.
I initially filly redesigned the metal insert, because I was thinking at meshing issue but even without meshing error message, I still have this error 4000.
Could you please help me to solve that problem?
The mesh elements between part insert and part itself were probably not “matching”.
Try to regenerate the mesh, and it should start running on your server.
Tip to create “matching mesh” – please untick “Allow non-matching faces” at preference setting interface.
