RE: EPS/EPP foaming simulation capability
Can Moldex3D simulate the EPS and EPP foaming injection molding process?
We do not support EPS or EPP foaming simulation. This type of particle-based foaming method is very different from the modules we currently have, such as Mucell/PU foaming. There are uncertain physical behaviors and chemical reactions in between. In current solution, we are not able to bypass by using FIM or chemical foaming.
